[SOLVED] AWR NXP Simulation Issue
Mahruz
Junior Member level 3
Hi All,
I am relatively new to Cadence AWR and would like your help in my question.
So, I downloaded the design files of a LDMOS transistor from NXP(https://www.nxp.com/products/radio-...ideband-rf-power-ldmos-transistor:AFT05MS004N)
1. I imported the S_Para files into AWR's "data file" and was trying to simulate the IV Curve as shown below:
But despite doing that, the IV Curve is not what I expected.
2. Another questions is:
I downloaded the AFT05MS004N RF High-Power Model AWR Product Model Design Kit from the same URL above.
Similar to the first question; after I execute the following steps: 'new with library' --> browse for the library and install it as shown below:
When I use the component from the elements--> library; i get a 6 port sub-circuit instead of a 3 port(like a normal transistor).I am not sure on how to make the connection on this to obtain the correct IV curve. Also, why can I not see the transistor symbol instead of box?
Lastly, even if do connect some of the terminals; Awr shows an error
10:37:41 PM FSL_AFT05MS004N_Level1_Rev0_SPmodel_FET2.X1 : Element record not found for nonlinear model 'FSL_AFT05MS004N_Level1_Rev0_SPmodel_FET2.X1' component 'FSLRFPK_FET2'
It will be greatly appreciated to see the forums response.
Thanks,
S-parameters are not used in IV Curves. You should place nonlinear models.
--- Updated ---
Download ;
then Download;
Create Directory
C:\Program Files (x86)\AWR\Foundry\Freescale
Extract 2 files into this new directory.
After that Copy /merge
C:\Program Files (x86)\AWR\Foundry\Freescale\RF_POWER_AWR_DESIGNKIT_AWRE_V13\NXP\Common
directory into ( there should be another Common Directory )
--- Updated ---
Reactions: Mahruz
    bassa
Hi Big Boss,
Thank you for your answer.
After following it, it worked for it.
Thanks,
