DSPF syntax for commenting
sutapanaki
US
I am using an extracted netlist DSPF file and I need to comment a bunch of lines. I was wondering if there is a possibility to comment everything at once. I tried /* */ but it doesn't work and generates errors when I started the spectre simulation. Of course, I can always go and put * at the beginning of each and every line but that will be a lot of * and time needed to spend on this.
Use vi:
vim file.dspf
Esc:set nu
Esc:n1,n2s/^/*/
(n1 and n2 are line numbers - '*' will be added for all lines between n1 and n2; "s" means "substitute", ^ is beginning of line).
Do you know what the nedit macro will be for that purpose - adding * at the start of every line in a selection of lines?
The simple way s to copy line comment macro for C/C++ and replace // with *
1. Change syntax highlighting to C
2. Copy comment macro for C: Preferences→Defauklt Settings→Customize Menus→Macro Menu
3. Select Comments>// Comment@C@C++@Java@JavaScript and push copy button
4. Change // to * in macro command and Menu entry like below:
5. Repeat for uncomment
6. Select Block and run Comment macro:
"Simple things should be simple, complex things should be possible".
Apparently, whether a "thing" is simple or not, depends on the tool, and on the training/education background.
I understand there is a barrier in learning "vi", but once you overcome that barrier, many things become simple and efficient...
