Replacing Lm741 with tl082
Changes? Replace the LM741 with the TL082.
Test it and see what happens.
If there are any problems, then give us a detailed description of the problem.
Klaus
The LM741 is a single opamp but the TL082 is a dual opamp with completely different pin numbers.
Use TL081 single opamps instead that has the same pin numbers as an LM741.
Keep in mind, as the circuit is an IA you expect to have high CMR (Common Mode Rejection)
to get rid of signals that contaminate your signal path. Like lighting controllers, SMPS power
sup[plies, poor grounds....Your fdbk resistor accuracy most important when you are doing this.
An example -
Thats why most designers use IAs that are laser trimmed in production.
Topologies w/o high precision components, attached.
Attached R calculations for CMR.
Regards, Dana.
  • Hi CMR without precision Rs.pdf
  • CMR Analysis IA.pdf
AOL difference if 50% is huge ... especially when both Opamps are on the same die (TL082)
AOL of TL082 is much higher than LM741.
On the other hand 60dB is not that bad for this application.
Klaus
I would definitely take this to a production engineer for comment.
I will contact AD on this. As a past production and test engineer I would not
bet the farm on this.
Multiple OpAmps on die to create IAs are Laser trimmed because of variations.
Regards, Dana.
There's a big difference between "normal" and "worst we would like to be able to ship" IME. We always sandbagged to 3 sigma test / char data (or wider if a hard to test param) on the datasheets.
    d123
OP talks about simulation, not about mass production of a professional medical device.
The circuit behind the link is clearly from a hobbyist..meant for hobbyists.
The description is incomplete and so is the whole circuit. There are a lot of errors in the description.
Thus I see it rather relaxed.
Klaus
Are you sure you talk about the OP's circuit / requirements?
Hes worried about using TL082 instead of LM741
I mean they (in the link) used two single LM741 and you talk about laser trimmed instrumentation amplifiers.
But I agree with you: They don't play in the same league.
Klaus
He is making a simulation, not a real circuit.
Don't all separate opamps in a simulation match perfectly and there is no common-mode interference?
Yes if ones sims are with ideal components....no simulating spreads and tolerances, no Monte Carlo
sim. But then we are assuming thats all he is going to do.
OP, is this an exercise or a real design goal ?
Regards, Dana.
Klaus
The answer I got from Analog Devices is that variation between amps would
be covered by min/max values speced in datasheet for Aol and BW. The
response frankly did not come from either a Test EE or a Production EE, they are
generally speaking keepers of device characterization responsibility, as
he included "if there are any variations". You can look at dice layout handbooks
and in these generic opamps, they are not interdigitated structures, therefore
each amp experiences different thermals and/or bias and/or parasitics and/or....
Here is a 324 die, clearly not inter digitated.
The LM324 Aol spec is 25K min to typ 100K, so variation could be quite large.
This all supports why IAs are laser trimmed on production line to get the performance
needed.
Regards, Dana.
