Two 12A 250VAC inrush relays in parallel?
cupoftea
Advanced Member level 6
Until one of them starts to develop contact resistance, and
then current-sharing goes out the window (maybe this will
lead the other to "catch up", but maybe not). Similarly if the
actuation is mismatched in time, you might not get the
sharing you'd hope, and one takes the inrush current / turnoff arc
punishment while the other takes it easy.
You'd have to ask the mfr for overstress life test data, and
prepare for disappointment (customers used to pester me to
follow them down their rabbit-hole and tell them violating
abs max / rec max conditions was OK; but do it once, and
why have ratings at all?).
Hard to believe there's not one suitable 25A relay out there.
Maybe you are now looking for "contactors", but still - the
job is getting done, somehow.
Paralleling relays doesnt work like expected.
There is timing mismatch making the fastest "ON" contact to carry all the switch ON current for a short time.
Also the slowest turn OFF contact caries all the switch off current .. and most probably builds the arc.
Klaus
Thanks, as such, we will see about putting in zero cross detect and only switch them at mains ZX...so no current flows through them when they switch.
Also, for when the relays are closed...do you think it would be worth adding series resistance with each so that they share current better?....eg one of these 10milliOhm resistors?.....
Ohmite 630HR010E 3W 0.01R resistor
Can you actuate a relay fast enough to stay anywhere near zero crossing? At 16ms (or 20 for youse on the right side of the pond) full cycle time) it's maybe 4ms from zero to peak. You may need to "lead the duck" to hit it.
Thanks, great point, i was forgetting that......though i still wonder if the "sharing resistors" are a good idea? (i think with the switching, we will have to only switch the relay when the caps are totally full...then zero current through relay when they actually switch.
I use a triac with a relay connected across it. The triac is fired by a ZCD opto isolator and the relay contacts close a few cycles later. When switching off, the relay contacts open a few cycles before the triac turns off. So the surge is dealt with by accurate zero crossing and the triac but the relay contacts carry all the current immediately afterwards. It's a low cost, simple solution that also removes the strain and arcing risk on the contacts while the triac dissipates virtually no power.
I use it for switching large single phase pumps that draw about 30A at start up. Been in use for about 20 years, switching maybe 50 times a day with no problems.
Brian.
