stenzer
Advanced Member level 3
I want to record some digital audio files from a PC to an audio-cassette. It seems the only casette recorder I can get hold of at the moment is a Thoshiba RT-SF1, which provides a microphone input using two 3.5 mm jack connectors, one for the Left & one for the Right channel, as can be seen below. The microphone input impedance is stated with 200 Ohm to 2 kOhm. I assume each input is using a mono jack, so I should be able to feed in the audio-signal provided by a PC by a stereo-jack to 2 x mono jack cable. Is this assumption correct?
Unfortunately I was not a able to find a service manual. It would be nice to have a look at the schematics, as I have to change some potentiometers in near future. So I would be happy if someone could share the service manual.
BR
BR
