[SOLVED] need help using multiple serial ports on Arduino MEGA
johnny78
Full Member level 5
Full Member level 5
hi Guys
this code should read serial data coming to serial 1 on arduino mega & display it on serial monitor using serial 0
would you check it please ?
thanks
Johnny
String inputString = "";         // a String to hold incoming data
bool stringComplete = false;  // whether the string is complete
void setup() {
  // put your setup code here, to run once:
  Serial.begin(9600);
  Serial1.begin(1200, SERIAL_7N1);
void loop() {
  // print the string when a newline arrives:
  if (stringComplete) {
    Serial.println(inputString);
    // clear the string:
    inputString = "";
void serialEvent() {
  while (Serial1.available()) {
    // get the new byte:
    char inChar = (char)Serial1.read();
    // add it to the inputString:
    inputString += inChar;
    // if the incoming character is a newline, set a flag so the main loop can
    // do something about it:
    if (inChar == '\n') {
      stringComplete = true;
Please give an error description.
Klaus
Klaus
no error
but i dont see anything on the output on serial monitor or the tx led on arduino MEGA
& the output of the scale of 1200 7N1 is writing data im sure & tested on another device
i think the code is easy & it should work
right ?
is it possible this MEGA board serial ports are damaged or else?
im not sure of this chinese clone which looks bad also
i will try to get another one tomorrow
or give me an idea to test the serial ports on the board
thanks
Johnny
The function "serialEvent()" isn't being instantiated anywhere on your code.
this info from Serial Event example in Arduini IDE
SerialEvent occurs whenever a new data comes in the hardware serial RX. This
routine is run between each time loop() runs, so using delay inside loop can
delay response. Multiple bytes of data may be available.
Johnny
Your code didn't work on my mega either.
There are several ways to do this. One possibility would be:
char inputString[20];   // allocate enough memory for expected incoming string length
int num = 0;   // point to next char in string array
void setup()
  Serial.begin(9600);
void loop()
  if (stringComplete)
  if(Serial1.available() )
    // place it into the inputString:
    inputString[num++] = inChar;
    if (inChar == '\n')
      num = 0;
    johnny78
Your code is working
the Serial Event example works only with Serial i guess because the example is working
so i guess the serial event isnt working with Serial1
if you guys check this will be great
thanks
Johnny
There is a line that I left out on the code I posted above.
inputString[num] = 0;   // terminate the string with a 0
It should be inserted in the section
    if (inChar == '\n')
      num = 0;
void serialEvent() may have needed to be void serialEvent1().
    johnny78
i didnt notice this thanks Alot its working now with serial event the same old code i posted here
one Final issue
i read the scale on arduino Mega Serial1 & display the result on Serial monitor
this is a reading from the scale
S S 189.71 g
i have used
lcdData.replace("N", "");
  lcdData.replace("S", "");
  lcdData.replace(" ", "");
Im using ATMEGA32 with mighty core on Arduino IDE & displaying on 5 seven segment displays
i get 0.00 on the display
when testing a Float type Var it displays the 5 digits exactly same as the number
float test = 976.58  ;
sevseg.setNumberF(test, 2);
i think its something about conversion of types
need your help guys
thanks
Johnny
--- Updated ---
thank
one Final issue
S S 189.71 g
i have used
need your help guys
thanks
Johnny
its ok i just converted it to float Type
its done
