nidare
Junior Member level 1
Hi
I am working on a LDO design that requires a rather large PMOS pass transistor due to the specified max current.
I have issues with pulling the pass transistor gate high enough at no load conditions to avoid the output voltage creeping upwards due to leakage in the pass transistor.
In certain corners the output voltage with no load increases around 3% which looks a bit scary.
My first question: Is this a common problem?
There is no feedback network as the reference voltage is equal to the output voltage but I have added a “dummy” load at the output that will always draw a certain current in an attempt to reduce this problem. By increasing this dummy current to about 1% of the max output current the output voltage starts behaving more nicely with no external load.
My second question: Is this commonly done and is wasting 1% of the max output current in a dummy load generally regarded as too high?
I guess the problem also relates to the output swing of the error amplifier stage as it can only swing up to one VDSAT from the supply rail?
To my understanding this can be maximised by making the VDSAT as small as possible (high W/L, low bias currents), also to be able to swing as low as possible to minimize pass transistor size.
My third question: Is it any topologies/tricks that can be done to pull the error amplifier output as far up as possible?
