circuitking
Full Member level 5
Dear all, I would like to generate a pulse signal with varying pulse width with in the given time limits. The center of all these pulse should be in the same place on the x-axis. I used variables for delay time and pulse width for Vpulse component in analoglib and did a parametric analysis but there should some other way because the parametric sweep includes signal outside the given range also.
