cupoftea
Advanced Member level 6
We are doing a 48V 7A5 PSU with TUNS500F ACDC power module.
We want it to limit current if a 10A load is connected, so the contractors made the attached overcurrent circuit as shown. Do you think it will damage the TUNS500F “TRIM” pin, due to >5V experienced on that pin? (>5V on TRIM pin when overcurrent happens)
Attached is a representative LTspice sim of the added overcurrent circuit, and a PDF schem of it
TUNS500F datasheet (page 8)
https://en.cosel.co.jp/tool/tag/pdf/SFE_TU.pdf
Page “TUNS-27” of the below, says TRIM pin should not have >5V applied to it….
https://en.cosel.co.jp/tool/tag/pdf/CME_TU.pdf
