tony_lth
Advanced Member level 5
Hi, Gurus,
In one TI 77G desgins, it used the following as antennas: 3 TX , 4 RX.
And I simulated the 3 TX antenna's spec as the attachments.
The problem is the TX beamwidth is too samll.
I need to design a shell over all the antennas, the problem is I can opt the shell height over the board and shell thickness for the TX antenna.
Then I can opt the shell height over the board and shell thickness for the RX antenna.
The problem is that the two opt results will be different.
So how should I do? Tradeoff or some other ideas?
Best,
Tony Liu
Best,
Tony Liu
