Thermal Fuse Manufacturer
stenzer
Advanced Member level 3
I'm repairing a coffee machine (Miele CVA 2660) where the thermal fuse mounted on-top of the hot-water heater has tripped (open). Does anyone know the manufacturer of the fuse shown in the attached picture?
The writing on the package is:
Tf 184 °C
D181 PT US
BR
thank you. Yes this might be the correct manufacturere as the logo looks like an M with a T in between (to me).
BR
I once replaced a blown thermal fuse in a fan. The replacement was from Radio Shack for a few dollars. They carried a few different temperature ranges.
I seem to recall choosing the next higher temperature above the original fuse rating, in hopes it would survive better.
Another major manufacturer is Cantherm. Consider that tripping of the thermal fuse usually indicates malfunction of the main thermostat, it should be checked and possibly repaired before replacing the fuse.
the reason for the blown fuse was a malfunction of a NTC which is used to monitor the hot-water heater's temperature. The NTC failed open, consequently the hot-water heater got too hot. I assume this was some kind of "smooth" transition, I do not expect a heating of the hot-water heater in case of a broken sensor signal.
BR
Fitting products on distributor stock:
    stenzer
Thank you,
I was already considering the linked thermo-fuse from Buerklin. Interesting thing is the rated maximum/overshoot - temperature. The Datasheet from Buerklin states a temperature of 210 °C, whereas the datasheet available at the manufacturers webpage [1] states 240 °C.
[1] https://asset.conrad.com/media10/ad...4-c-10-a-250-vac-o-x-l-4-mm-x-645-mm-1-st.pdf
BR
--- Updated ---
I figured out who is the manufacurere of the thermal fuse shown in the picture, it is Elmwood Sensors (now Honeywell). According to this document [1], the original fuse is rated for 16 A. So I will use a 16 A one as well [2], although a 10 A one should be sufficient (hot-water heater has a power rating of 1200 W).
The 16 A version provides a larger thermal safety range, by means of its maximum overshoot temperature of 350 °C.
[1] https://docs.rs-online.com/ec9a/0900766b80029806.pdf
[2] https://asset.conrad.com/media10/ad...4c-thermal-fuse-184-c-16-a-250-v-ac-1-pcs.pdf
BR
