5 digits 7segment display
johnny78
Full Member level 5
Full Member level 5
hi Guys
i need to display my scale weight on 5 digits 7 segment display
i've used Dean reading Arduino library for this & it works for 5 digits
how to display numbers with decimal point?
ive tried to declare the variable as float but it didnt work
float test = 99.5;
this shows number 100 on the display
i have read about the data types But i couldnt understand why it shows 100
what do u suggest ?
here is the Library i use
thanks
Johnny
Fixed?
Or variable? In which range?
I usually try to use fixed decimals.
So if 2 decimals, then the range is 0.00 to 999.99.
I treat it as an integer with range of 0 to 99999.
So basically this means a range of 1:100000 , which is more than a 16 bit variable can handle.
So it's not only the decimals range we need to know, but also the resolution ..
and if the value is signed .. and how to treat it.
Klaus
hi Guys
float test = 99.5;
what do u suggest ?
thanks
Johnny
How do you send this value to 7 segm..
test=99.5;
sevseg.setNumberF(test,1);
    johnny78
test=99.5;
hi Mr
i use sevseg.setNumber(test);
why you use F & (test,1);?
thanks
--- Updated ---
Fixed?
Klaus
Hi
its variable value i get from an electronic scale
yes the reange is 0.00 to 999.99.
what do you mean by resolution ?
signed you mean like negative value with -?
yes sometimes it is & i should add another segment to display this
thanks
Johnny
The documentation tells me the "..F" is for float numbers. And 99.5 is a float number. No integer.
0.00 to 999.99: so it´s fixed two decimals.
How do you want to treat negative numbers, because obviously -999.99 is not possible.
resolution:
with a 5 digit you may show positive values 0.0000 ... 0.0001 (or even .00001) .... 99999
so the resolution could theoretically be .00001 (10 micro) and dynamically adjust the number of decimals.
Klaus
    johnny78
which documentation ? like Arduino reference ?
why using the 1 after the varible ?
anyway i have tried this method but it gives me error when compiling
'class sevseg' has no member named 'setNumberF'.
i may get 000.00 to 999.99 but sometime when u carry out the load of the scale it may give negative value
because of the mechanical springs .
its small vallue like -001.00 lets say so its not important much but im interested to know how can i solve this issue
resolution:
thanks for the direct answer
you help is very Appreciated
Johnny
Hi
In post#1 you posted a link to the GitHub library with it´s readme.md. Just scroll down a bit.
It tells you the difference between setNumber and setNumberF and how to use them.
Negative values:
You are free to differentiate between negative and positve values.
So you are free to use 000.00 to 999.99 as positive values
and -00.00 to -99.99 as negative values (mind the most left digit is used as "minus" sign, leaving just 4 (out of 5) digits to show values.
Klaus
Hi
i have tried to read this file but i couldnt find an app to open md file
will google it
Negative values:
i will another segment to show the minus sign i was planning for it
thanks
Johnny
Hi
No need for an app. The text already shown.
As said: just scroll down.
Klaus
Hi
i've tried to read it from the downloaded file first
then i opened it in the github
it was the same method but the version i was using is older & seems like it does'nt support this feature
i have used:
(float test=987.5)
(sevseg.setNumberF(test))But i didnt get a decimal point
then used this
(sevseg.setNumberF(test, 1);& the decimal point is here finally
what is the 1 added after the test variable? that was mentioned by Paulfjuju?
thanks
Johnny
What are yo doing?
No need to open a file. Click on your link in post#1 (github) and then, again: just scroll down.
The functions and their parameters are explained there.
(Do we see a different internet page than you ???)
In either case it should be possible to do a browser search for "setNumberF" on the github page.
Klaus
    johnny78
Hi
i have used:
(float test=987.5)
then used this
thanks
Johnny
Hi
Got it finally
Floats are supported. In this case, the second argument indicates how many decimal places of precision you want to display.
its all done i guess
thank you
Johnny
