Orizine
Newbie
Hello,
Sorry for if the question if I'm not clear, i'm not nor développer, nor electronician , but i've done a small project with esp32 to do a full duplex audio stream, well done , but now I have a problem to connect the microphone i want to use without have too noise.
I want to use a old headset of phone in what i have an electret microphone and speaker with RJ9 wire (4 connector), one pair is for speaker, that work perfectly, and the other pair, is for the electret microphone CMA-4544-PFW in the headset, and i have to connect to a max9814 near to my esp32 with an rj9 cable with speaker pair in the same. The module work perfectly when the microphone is directly connect on the max9818, but when it is far and connect with the RJ9 where the two pairs of wire are in the same cable i have really too much noise. I know my problem is not really an electronic or developpement problem, but i really dont know how to correct this audio connection problem, and i hope some of you know something that could help me .
I think as the headset was already connect with the same type of microphone to a telephone like this https://www.google.com/aclk?sa=L&ai...wif_sSBzeH0AhXD7OAKHft5DF4Qwg96BAgBEBo&adurl= without noise problem even if the speaker is active, i suppose there is a method ( capacitor? Resistor ?) To make that possible...
I'm sorry that i can't share my code project nor the electronic schem, but actually, i don't know how to do as i said, it's the first Time i use a microcontroller board and first time i devellop something other that HTML/PHP things, and first time also i work on an audio project... Really sorry
I prey for tour help .
Thanks, i promise to share all that as soon as possible .
