cupoftea
Advanced Member level 6
Just seen layout for a Buck prototype from an external contractor. Its 24V and 0.5A out and 32Vin. Uses Monolithic TPS5401 controller. Its on a 2 sided PCB
They have failrly well minimised the area of the switching node. However, they have not put ground pour under the switching node, presumably because they fear the switching node will introduce noise into the ground. The Bootstrap cap obviously has switching nodes on each of its terminals....and there is no copper pour underneath that either.
This abscence of copper pour in this place has meant that the current loop from the "innermost" input capacitor, and through the FET and inductor, and then on through the "innermost" output capacitor, is unfortunately wider in area than it needs to be. This is unfortunate.
(By "innermost", i mean 'nearest to the switching FET'.)
Is it a good idea to avoid having ground copper pour beneath a switching node?...even if it makes the switching current loops bigger in area?
