sabu31
Advanced Member level 1
Hi all,
I am developing a pulse transformer with input 0-500V and output 0-4kV at 78 ohms load. The pulse width maximum is 10us. And the frequency is 250Hz. The core used is amorphous metal core (UMCCC-400). Cross-section area is 12.5cm^2. The approximate magnetizing inductance is nearly 112micro-henry.
I tried two configurations of the transformer. And the winding diagram is attached
In the interleaved case, I am getting lower ringing, but the audible noise is higher (around 60-70db). In the configuration where the primary is parallel and secondary is series, the audible noise is lower (still not comfortable) but the ringing is higher. Surprisingly the leakage is nearly same around 900nH. My queries are
How can I reduce transformer Audible noise? I covered each layer with Kapton tape.
Will keeping one terminal of secondary grounded reduce the ringing
