40 Watt Variable resistance needed
T
treez
Newbie level 1
Hello,
I need to make or get a 40W variable resistance , which is to be as non inductive as possible.
It will carry a current which is a constant 1.9Arms , 50kHz , sinusoidal current.
So the resistance has to be variable from zero Ohms to about 11 Ohms.
Ive found this but its too high resistance and looks rather too inductive
Do you know who makes these things?
compare.ebay.com/like/400297863039?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
50 Watts 10 Ohm the price is 14 bucks
Reactions: treez
    T
You may consider some thing like this
Best way is to Google with key word 'Non inductive potentiometer / Rheostat'
Hope this helps
Coincidentally this is also form e-bay but the comparison of available options is limited.
Reactions: treez
    T
