[SOLVED] 4 Stage feedforward amplifier design question on phase dip
jgk2004
Full Member level 5
Full Member level 5
Munich Germany
Hello all,
I am designing a 4 stage feedforward compensated amplifier and I am seeing a phase dip, see attached. I am wondering what people commonly consider reasonable dip when design 4 or higher stage amplifiers. Over all i am always above 40degrees. Also this amplifier will not be used as a follower but as an integrator, so i feel i shouldn't have a probem with instability.. What do you guys think?
Jgk
Hi John,
just a practical hint: simulate your amp within its application environment, i.e. as integrator, perhaps with artificial parasitics to be expected from layout. For w.c. use a steep step edge and see if you notice some ringing in the low phase margin frequency range. Even if so, it probably won't hurt.
erikl
Hi Erikl,
I have already done this and I do not see anything in the time domain. I have also added expected parasitics and have seen no change as well. I just wanted to double check with the edaboard to see if anyone else has made one of these before and seen a similar PM and had problems with there measured performance. Have you made one before?
Jgk
Hi Jgk,
I think, you shouldn't expect any problems using the shown circuit (resp. its Bode diagram) for amplifier or integrator applications.
Its quite normal that the phase goes up again if the gain slope changes from -40 to -20 dB/dec.
More than that, this phase increase is the only reason for this slope decrease.
Be aware that such a dip is caused by a pole/zero doublet so you will have a slow settling component to your circuit.
Yes that is true, but I still have a fast part within the two stages to the output. I would only have the doublet when looking through all 4 stages. So I would say I shouldn't have a problem with settling.
Jgk
Jgk
I don't understand how the zero that is used to offset the pole won't affect your settling. Can you elaborate?
rg
Sure!
When looking at the attached figure there is a path to the output which doesn't have the pole zero doublet, 2 stage path on the top, 3 stage in the middle, 4 stage on the bottom, thus you will still have fast settling. I have attached a tran of the amplifier.
Jgk
