dampsquib
Newbie level 2
Hi, I hope you can help, this is probably an easy question, but I'm not that good at electronics.
I want to make a circuit that will take one of 4 pulsed inputs (from a momentary action footswitch) and provide an output to power an LED indicator to show which input was used. Would i use 4 SR latches, with each switch tied to one particular set input and the other 3 resets, with the q output being enough to trigger an LED?
Is there an eaier way?
