Hello everybody
I'm asking myself - and would like to ask you - why in the usual case people do not choose the bottom layer of a 4 layer pcb for a power plane, but rather the third layer.
I see the following advantage in using the proposed layer order: Both signal layers are close to the ground plane, which lets one avoid the discontinuity of the return current path (which must in the usual case "jump" from ground plane to power plane or vice versa) when placing a via for routing.
Should I nevertheless use the "traditional" layer order, i.e. top = signal, 2 = gnd, 3 = power, bottom = signal?
