Palpurul
Member level 3
Hello,
I'm designing a 4-layer PCB and I finally finished routing, but I am kind of confused about a grounding of the last layer in my PCB.
I went with a very conventional stack-up:
1-layer - signal routing
2-layer - GND
3- layer - PWR
4- layer - signal routing (almost blank)
I almost only used the first three layers, 4th layer is almost blank. I am thinking about grounding it (of course). Should I connect this layer with all ground vias in my PCB (that's what I did with the second layer) or should I connect this layer to the ground with only one fat via?
Thanks!
2-layer - GND
3- layer - PWR
Thanks!
