sizo0708
Hello everyone,
I simulated a matched full wave rectifier and measured the DC output voltage on the load with an input of -20dBm.
Results below:
After that, I tried to simulate 4 voltage multipliers and combine all the output DC voltages to a common load to achieve something resembeling this block diagram:
I expected to receive an output voltage of at least 500mV because this is the sum of the combination of all the output DC voltages, but unfortunately these are the results:
I think this is because the connections of each full wave rectifier to the load and the connections of the rectifiers to each other are wrong, because the output caps are connected in parralel instead of in series to the load ressistor but im not sure how to properly connect it.
Guidance will be much appriciated!
Results below:
