Junus2012
Advanced Member level 5
Hello,
below is the simple current starved ring oscillator,
I have removed the transistor Ts and simply sourced the circuit with ideal current source. According to the working principle, the charging and discharging time will be controlled by constant current source, and since the current is constant, then frequency of oscillation should be stable and not sensitive to temperature. However, the circuit during simulation is showing me sensitivity, what is the reason
If I want less sensitive to temperature clock oscillator will the fully differential delay stage would serve better, or you suggest me to move to more accurate scheme like other types of relaxation oscillator?
Thank you
Thank you
