IanP said:If you want to use it as a switch to turn loads on/off then instead of R1 use a switch, and L1=100µH, and all capacitors should be rated at 230Vac (≈400Vdc).
Regards,
IanP
means that the load can be connected as on FIG8 (preferred option), between triac and Neutral, or it can be connected between Active and triac. In this case the bottom part of triac will be connected directly to Neutral.But you can use this circuit for both sides switching: Active and Neutral
