T
treez
The common mode range of MCP6001 does appear to be VSS-0.3V to vdd +0.3v, so I presume, if I connect it as a buffer, and put 50mV on the non inverting input, then I will get at least somewhere inside 50mV +/-7mV at the output?
(it will be on single 5v supply)
MCP6001 opamp
https://ww1.microchip.com/downloads...1U-2-4-1-MHz-Low-Power-Op-Amp-DS20001733L.pdf
MCP6001 opamp
