T
treez
Hi
The page 1 schem (and all other schems) in the datasheet of the LT1681 Two Transistor Forward controller show an input LC filter.
If a 70V input voltage is “hot plugged” into this, then it will ring up to some 140V, thus overvoltaging the LT1681, and possibly destroying it…Since the chance of this happening is quite likely, why don’t the schems show the necessary inrush limitation circuits that will be essential for use with the LT1681?
LT1681 datasheet
https://www.analog.com/media/en/technical-documentation/data-sheets/1681f.pdf
LT1681 datasheet
