FreshmanNewbie
Advanced Member level 1
In a Superheterodyne receiver, let us assume, I have a signal in the RF Range of 88MHz to 108MHz.
From what I have read, my understanding is that by tuning the local oscillator frequency, we can make the incoming RF signal to fall within the IF frequency range which we have designed.
My questions :
Suppose, I have a frequency of 95MHz. And My IF filter is designed at 98MHz (Am I correct in assuming this value for the IF Filter?). So, the signal after going through the filter, will come as a signal having 98MHz, right? But my actually signal is 95MHz. And all my modulation is done at 95MHz. Not after the filter, the signal is converted to 98MHz. Won't my actual signal present in the 95MHz, be lost or tampered with filter?
In other words, how is the modulation retained even after passing through the IF Filter?
Does high carrier frequency imply that more information can be carried and Low carrier frequency imply that less information can be carried per unit time? Can someone explain.
My questions :
