sabu31
Advanced Member level 1
Dear All,
Please could you suggest references for flyback transformer construction.
I have two doubts
a) Whether one should fix air gap first (say at 0.1mm) and then calculate turns based on AL value (as most of the data sheet gives AL value with specific gaps such as 0.1mm onwards but not less). However, in these conditions I am getting operating B at around 0.1T , whereas most commonly its suggested to use at 0.3T.
c) Whether high voltage coil should be wound first and then low voltage or vice versa and what should be pattern of winding if there are number of layers. What are the issues.
Are ther any design tools which can give winding construction details.
Thanks and regards
I have two doubts
Thanks and regards
