KhaledOsmani
Full Member level 6
Hi
Considering the following interleaved DC-DC buck converter:
I've tried to built the above circuit via Proteus, and fed HIN and LIN of the two IRS2003 MOSFET drivers by a configurable function generator.
The PV+_DWN of the two sub-divisions are fed from a 24VDC supply (this is assumed theoretically that a PV panel is outputting a constant 24VDC).
Regardless the option of choosing an interleaved non-isolated buck converter, but, with a 50% PWM (from configs of pulse generator) isn't the output voltage must be seen at 12VDC?
After branching a DC voltmeter across VOUT_UP I`m seeing non-stable voltage values maximizing at +7.03V.
What am I missing here?
Khaled
Khaled
