Mabrok
Full Member level 4
Any one have an experience with CGH40010F transistor provided by cree company especially at the fabrication process?
i am going to use the mentioned transistor in PCB fabrication, and I am not sure about the grounding of this type of transistor? My PCB will be double sided copper, and the back side is consider as a ground. So, my question is: is it correct to use two screws through the two holes of the transistor to make the connection to the ground "back side of the substrate"? Attached is the photo for that transistor. Thanks in advanced.
