MSAKARIM
Full Member level 3
Dear all, Plz i need some help.
I have an error with this code but unfortunately i can't recognize it.I'm using Xilinx ISE14.7 as a tool
behavioral check syntax is performed successfully , but Simulate behavioral model is stopped due to these errors:
ERROR: Index 64 out of bound 63 downto 0.
ERROR: In process sha256_exp_unit.vhd:33
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
use work.sha256_pkg.all;
entity sha256_exp_unit is
port(
clk : in std_ulogic;
rst : in std_ulogic;
en : in std_ulogic;
mi : in word;
sel : in std_ulogic;
wi : out word
end entity sha256_exp_unit;
architecture arch of sha256_exp_unit is
type wi_array is array(15 downto 0) of word;
signal wi_ff : wi_array;
signal wi_ff_0, sum_out : word;
begin
with sel select
wi_ff_0 <= mi when '0',
wi_ff(15) when '1',
(others => '0') when others;
sum_out <= std_ulogic_vector(unsigned(wi_ff(14)) + unsigned(sigma_lower0(wi_ff(13))) + unsigned(wi_ff(5)) + unsigned(sigma_lower1(wi_ff(0)))); --can be optimized
wi <= wi_ff_0;
proc_fifo : process(clk, wi_ff_0)
begin
if clk = '1' and clk'event then
if rst = '1' then
for i in 0 to 15 loop
wi_ff(i) <= (others => '0');
end loop;
elsif(en='1') then
wi_ff(0) <= wi_ff_0;
for i in 1 to 15 loop
if i = 15 then
wi_ff(i) <= sum_out;
else
wi_ff(i) <= wi_ff(i-1);
end if;
end loop;
end if;
end if;
end process;
end architecture arch;
P.S. Line 33 starts at this line sum_out <=
[ATTACH=CONFIG]157522._xfImport[/ATTACH][ATTACH=CONFIG]157523._xfImport[/ATTACH]
