T
treez
Do you agree that the LLC converter would be more efficient for the above case?
Consider synchronous rectifiers in each case.
The Buck would be a Dual cascaded Buck so that Duty cycle was not too small….also, the cascaded method means the downstream buck, that carried most current, can have a lower voltage mosfet with lower rds(on).
What I believe I am pinpointing here, is that the LLC is one of the few common isolated converters which suffers no efficiency degradation due to the transformer prescence, since the leakage inductance is just part of the power stage.
Would you agree.
Or what other way would you suggest?
Would you agree.
