Powerglide
Member level 1
I want to build my own full bridge dc to dc converter with 12v in and 400v output for 1.5kw load
I'll be using a sg3525ic to drive ir2113 mosfet driver, but I need help with a circuit layout. The only circuit I could find is this from tahmid.
https://tahmidmc.blogspot.com/2013/01/using-high-low-side-driver-ir2110-with.html
This shows an input voltage of 300volt and that's why I'm uncertain if I can use this circuit for a 12 volt input?
Will really appreciate some help.
