T
treez
As you know, its not difficult to design and build an offline SMPS LED driver that can run at 235W output, and also be dimmable down to 25W output. (eg, a Boost PFC followed by a 2 transistor forward converter).
However, its far more challenging to make it able to pass mains harmonic emissions at 235W, and also at 25W. This is because the EMC filter necessary to make it pass conducted emissions at 235W, will generally mean that the mains harmonics at 25W are not a pass. (the input stage filter capacitors will generally be too big to allow a mains harmonic pass at 25W)
Would you agree with this?
How do the regulations deal with dimmable LED drivers. At what power level are mains harmonics tested?
