T
treez
What are the reasons for a scope’s traces to suddenly get noisey (fuzz all over them)?
I am using the Tenma 72-8705 scope.
Today some offline LED driver PCBs came up from production having failed. I didn’t get too long to look at them before I got called away…however, as I scoped the nodes of these PCBs, I noticed that there was loads of noise “fuzz” on the waveforms. …I could barely see the signals. I have used this scope on this same board for months and months and never seen it noisy like that before . I wonder if someone has accidentally dropped the scope or connected it to a high voltage with one of its 10:1 scope probes and broke the scope like that?.....making it go “fuzzy”. Perhaps somebody connected it to a non-isolated mains LED driver and forgot to use the diff probe?
I tried using a diff probe instead, but the fuzz was still there (and it never was before when I used that diff probe with this scope). Also, the 10:1 probe I used has its lead wrapped several turns through a torroid. Also, I checked that the scope had “bandwidth limit” selected. Also, the waveforms were all still fuzzy whether the pcb was supplied from our usual AC source, or with the non-isolated mains and diff probe. This is the first time in 2 years I have seen this on this scope.
I will have a look on Monday and scope other things like PSU outputs to see if the “fuzz” is still there.
In the meantime, do you know possible causes of a scope giving noisy traces all of a sudden?...in situations where it never used to be “fuzzy” before.
Tenma 72-8705 oscilloscope:
TA 041 DIFF PROBE:
https://uk.farnell.com/pico-technology/ta041/probe-active-differential-powered/dp/1667343
TA 041 DIFF PROBE:
