kavin_eees
Member level 3
hi to all
right now am in developing three phase sequence detector using pic16f887 microcontroller. i had tried more methods but unfortunately the results are negative..
finally i planned to use inbuilt comparator in pic16f887 (2 comparators available) . i planned to fed the first two phase signal say R & Y to each comparator , and want to measure the time between the two signals.. the problem is how to measure the time after every raising edge or falling edge between the two comparator output C1OUT & C2OUT?
kindly share your valuable suggestion!
Thanks
kavin. s
Thanks
kavin. s
