hemnath
Advanced Member level 3
I have a analog pressure gauge of range 0 to 10bar. Is it possible to provide output of 4 to 20mA. I just want to try it. But don't know how to convert the mechanical to electrical output signal.
I assume, a magnet can be attached to the pointer shaft of pressure gauge. When the pressure is applied, the magnet on the pointer shaft rotates proportionally to the instrument pointer linearly.
This can be detected. Am I right? What sensor or IC is to be used?
