[SOLVED] Can't run mosfets in one leg configuration in LTspice
mAnmAN01
Newbie level 2
Newbie level 2
Hi! I am working with four pin mosfets (C3M0030090K). (Datasheet here- **broken link removed**) I want to drive them in one leg configuration like this- qw.JPG I am getting the pulse at load resistance of the circuit. new_config.JPG However, I am also getting similar pulse at gate of M1(which I shouldn't). I am using ACPL 337J gate driver. Here is the schematic- kk.JPG.
Spice model for ACPL 337J-
Library for 4 pin mosfet- View attachment C3M0030090K.txt
Symbol for 4 pin mosfet- https://drive.google.com/file/d/1yiCsuMkk9VExKUNYYgI7dTWg3fBR1u2l/view?usp=sharing
Schematic- https://drive.google.com/file/d/1JqMcO-ANgaLxRGY3UcqJYRYg1c426-zd/view?usp=sharing
Please suggest any edits in the circuit so that the circuit might work as desired.
I guess you did not measure voltage between gate and source of M1 as you should.
So why "can't run"?
Reactions: mAnmAN01
    V
    mAnmAN01
