promach
Why does this balun design (A 0.8–8 GHz Multi-Section Coupled Line Balun) give box resonance error in Sonnet ?
Note: Just rename the attached Multi-Section_Coupled_Line_Balun.txt to Multi-Section_Coupled_Line_Balun.son will let Sonnet open it.
Box Resonance Error
Box Resonance Error
Box resonances estimated for: Multi-Section_Coupled_Line_Balun.son
The estimated box resonance frequencies are listed below.
The calculations assume lossless materials, with a box filled with
only the specified dielectric stackup materials.
6.226 GHZ TM Mode 1,1,0
6.941 GHZ TM Mode 2,1,0
7.006 GHZ TE Mode 1,0,1
7.718 GHZ TE Mode 2,0,1
9.009 GHZ TM Mode 1,1,1
9.153 GHZ TE Mode 0,1,1
9.341 GHZ TE Mode 1,1,1
9.492 GHZ TM Mode 2,1,1
9.884 GHZ TE Mode 2,1,1
Only lowest order modes considered.
FTYP SONPROJ 13 ! Sonnet Project File
DIM
FREQ GHZ
IND NH
LNG MM
ANG DEG
CON /OH
CAP PF
RES OH
END DIM
FREQ
ABS 0.1 10.0
END FREQ
CONTROL
ABS
OPTIONS -d
SPEED 1
CACHE_ABS 1
TARG_ABS 300
Q_ACC N
END CONTROL
GEO
TMET "Lossless" 0 SUP 0 0 0 0
BMET "Lossless" 0 SUP 0 0 0 0
BOX 1 79.359277 23.997124 1250 378 20 0
20 1 1 0 0 0 0 "Air"
2 4.4 1 0.02 0 0 0 "FR-4"
LORGN 0 23.997124 U
POR1 STD
POLY 9 1
3 50 0 0 0 79.31161153 0.5693301799
POR1 STD
POLY 13 1
2 50 0 0 0 58.93250351 23.99712339
POR1 STD
POLY 25 1
1 50 0 0 0 1.146043145 23.98397036
NUM 18
0 6 -1 N 9 1 1 100 100 0 0 0 Y
79.31161153 -0.03337140237
64.26069456 -0.03337140237
64.26069456 1.172031762
79.31161153 1.172031762
END
0 6 -1 N 10 1 1 100 100 0 0 0 Y
64.26179217 0.3948257219
45.64768726 0.3948257219
45.64768726 0.7945943407
64.26179217 0.7945943407
END
0 6 -1 N 11 1 1 100 100 0 0 0 Y
58.72802453 1.602521757
45.64201941 1.602521757
45.64201941 2.002290401
58.72802453 2.002290401
END
0 6 -1 N 12 1 1 100 100 0 0 0 Y
59.12723737 1.602664404
58.72746796 1.602664404
58.72746796 9.612774012
59.12723737 9.612774012
END
0 6 -1 N 13 1 1 100 100 0 0 0 Y
59.5352047 9.606408035
58.32980231 9.606408035
58.32980231 23.99712339
59.5352047 23.99712339
END
0 6 -1 N 14 1 1 100 100 0 0 0 Y
45.64484635 1.798264851
32.84169375 1.798264851
32.84169375 1.999847125
45.64484635 1.999847125
END
0 6 -1 N 15 1 1 100 100 0 0 0 Y
45.65068632 0.3914119619
32.84753407 0.3914119619
32.84753407 0.5929942359
45.65068632 0.5929942359
END
0 6 -1 N 16 1 1 100 100 0 0 0 Y
32.84169375 1.600078506
19.93059112 1.600078506
19.93059112 1.999847125
END
0 6 -1 N 17 1 1 100 100 0 0 0 Y
19.93643107 0.3914119619
19.93643107 0.7911806061
32.84753407 0.7911806061
END
0 6 -1 N 18 1 1 100 100 0 0 0 Y
11.52684052 1.399312461
10.92391452 1.399312461
10.92391452 8.582487579
11.52684052 8.582487579
END
0 6 -1 N 19 1 1 100 100 0 0 0 Y
19.93002681 1.399460517
11.52684052 1.399460517
11.52684052 1.997651904
19.93002681 1.997651904
END
0 6 -1 N 20 1 1 100 100 0 0 0 Y
19.93643107 0.3963674765
10.23509144 0.3963674765
10.23509144 0.9945588887
19.93643107 0.9945588887
END
0 6 -1 N 21 1 1 100 100 0 0 0 Y
10.83581137 0.9945596507
10.23509144 0.9945596507
10.23509144 7.782923798
10.83581137 7.782923798
END
0 6 -1 N 22 1 1 100 100 0 0 0 Y
10.23509144 7.18220407
0.03609072956 7.18220407
0.03609072956 7.782923798
END
0 6 -1 N 23 1 1 100 100 0 0 0 Y
10.93696799 7.981767851
0.7379672786 7.981767851
0.7379672786 8.582487579
10.93696799 8.582487579
END
0 6 -1 N 24 1 1 100 100 0 0 0 Y
0.6390151778 7.782923798
0.03609072956 23.98320605
0.6390151778 23.98320605
END
0 6 -1 N 25 1 1 100 100 0 0 0 Y
1.554119012 8.582487579
0.7379672786 23.98397036
1.554119012 23.98397036
END
0 6 -1 N 26 1 1 100 100 0 0 0 Y
2.304036029 9.983319474
1.652782746 9.983319474
1.652782746 23.98161545
2.304036029 23.98161545
END
END GEO
OPT
MAX 100
VARS
END
END OPT
VARSWP
END VARSWP
QSG
IMPORT YES
EXTRA_METAL YES
UNITS YES
ALIGN YES
REF NO
VIEW_RES NO
METALS NO
USED YES
END QSG
