How to generated different bit patterns in Cadence Virtuoso
Junus2012
Advanced Member level 5
Italy
Dear friends,
I am designing full custom shallow register,
to test my circuit I need clocks and different periodic bit stream, what is the appropriate signal source that support my test ?
Thank you very much
Why not use the vector file available in Cadence? I found this nice webpage from Columbia: https://www.bioee.ee.columbia.edu/courses/cad/html/vec.html
Dear Vivekroy
Thank you for your nice help, I will check to see if my ADE simulator support the UltraSim simulator,
meanwhile I read the article, it is very helpful and answer my demand,
only one issue, in this method it is assumed that I give an expected pattern of the output, while I want only to apply inputs and see the output.
Thank you again
Can't you just skip the output column in the vector file?
Reactions: Junus2012
    Junus2012
    V
Dear friends,
Thank you for your help
Please forgive my stupid question, I am unable to invoke the vector file, how can I edit or call this file from my simulator.
Thank you once again
