mtwieg
Advanced Member level 6
I've done a few boost PFC front ends, but am now looking at maybe giving the totem pole PFC a try. A brief literature search shows that it has many caveats, most of which derive from the fact that the AC line alternates between clamping to each side of the DC output bus at zero crossings.
It occurred to me that one way to get around this issue would be to replace the two low frequency FETs/diodes (Q3/Q4) with high frequency GaN/SiC FETs. Then split the main boost inductor between each line, treating both sides the same. You would be able to freely choose the common mode voltage of the DC bus relative to earth, or at the very least remove the large jumps that normally happen at every zero crossing.
The downside would be that those two extra high frequency FETs now have similar switching losses as the original two, so you would see a those switching losses approximately double. On the other hand, you could interleave the PWM phase of each leg, thus allowing for a smaller overall boost choke, and possible a smaller EMI filter.
Surely this isn't a new idea, but I don't know if it has a name (active bridge PFC?), and I can't find any literature on it.
