hello every one
if my 12v to 220v converter using Boost topology and have no isolation .
Whether this is contrary to standard?
Not isolated, what problems may be the cause In a boost converter ?
Thank you
This can't be a serious safety assessment without knowing any application details. Is the high voltage exposed to the outside, are there current limiting means? Isolation may or may not increase safety, depending on the connected circuit.I would advise that dc-dc converters with output voltages in excess of 60Vdc should incorporate transformer for the sake of safety and regulatory obligations. Battery-operated appliances should have a voltage rating not exceeding 75Vdc which is the maximum.
