adwnis123
Full Member level 4
I have built a circuit that is supplied by 12Volt, 560mA, solar panel, I have modified the solar charger circuit you see on the attachments (solar-charger-550x274), and I conclude to the circuit (modified_2). I did this from suggestions I got, and because the "solar-charger-550x274" didn't work. In position D
I have connected a Sealed Lead Acid battery that supplies a working circuit for my project.
I have connected the INA219 module (on place D) of the foto.
The problem is that when I plug:
a) The 12 volts power supply (A,B) I get: 7,07Volt, 0 mA, 0 mW
b) The 12 Volts power (A,B) & 6Volt Sealed Lead Acid battery (D),I get 6,81Volt, -1407,8mA, 9782,00 mW
c) The 6Volt Sealed Lead Acid battery (D), I get: 5,98Volt, 480,00 mA, 2842 mW
The Sealed Lead Acid battery is connected in parallel with the power supply.
The LM317 goes really hot, although I have mounted a heat sink.
The "modified_2" is the circuit diagram.
What should I do?
Alternatively, can I use a simple step down DC/DC converter with 12 Volt input from the solar panel, 6 Volt output connected to the battery and charge it?
Can the 12 Volt, 560mA solar panel charge the 6V, 4Ah Sealed Lead Acid battery and supply the rest of the circuit?
Thank you...
What should I do?
Thank you...
