T
treez
We have put one of the ECW-FD2J185K film capacitors onto our PCB. It is 1.8uF, 630VDC, and dimensions 25.3mm by 11.2mm by 16.5mm (= l x w x h).
In digikey and mouser this part is not immediately available in large quantities, in fact, only a few 100 pieces are immediately available.
This is a problem because it is a sure sign that this part will have supply issues…do you agree? (ie, if we get an order for 1000 boards say, then we probably won’t end up being able to quickly get enough capacitors in straight away).
Therefore, we looked for a second source. However, all the capacitors of this spec are bigger than the ECW-FD2J185K, so we wouldn’t be able to fit them on the PCB.
How can we find out if ECW-FD2J185K is going to be immediately available in large quantities (say 10,000 pieces), if we get an order for this many boards?
