d123
Advanced Member level 5
Four questions...
The 40.31 relay at the top of this datasheet is the one that I would use for a timed on/off AC 230V, 1000W heater circuit:
View attachment Relay 40 Series Miniature PCB Plugin 10A Finder.pdf
According to Wikipedia's page on Utilization Categories, "AC-1" is for "Non-inductive or slightly inductive loads, example: resistive furnaces, heaters". The relay datasheet says 2,500VA.
1) So, for a 250V AC, 10A relay it's okay to use, is it? Just want to check before burning the house down or anything equally horrific.
2) Is anything missing from, or incorrect about, this relay circuit?:
It's only meant to turn on and off approximately every hour while I am present, otherwise it would be unplugged.
3) I kept using PCB calculators last night to check and looking for info on FR4 and AC 230V, and as far as I understand, FR4 with 35um copper is more than suitable for this kind of circuit, so long as I respect creepage and clearance and track widths (and contemplate expected ambient temperature and expected enclosure/circuit?? temperature rise in the calculations). Correct?
4) 1000W/230V AC = ~4.4A, so could I even put the heater on the 2,000W setting (with an appropriate PCB) - which I never would as I hate excessive warmth and can't afford the subsequent large electricity bill anyway - and still not worry about the relay as it would only be using around 9A * 230V, and not the 10A * 250V it's advertised as coping with continuously? Or, is that wonky maths, ignorant of AC calculations?
Better to look stupid but put safety first, eh?
Thanks.
Four questions...
Thanks.
