Fc = 1 / ( 2 × Pi × R× C).
With R = 60k and C = 0.1uF then fc = 26.5Hz.
Now that the output capacitor already suppresses those 26.5Hz you won't see or hear much difference.
Additiinally you'd need a very big bass speaker that is able to reproduce 26.5Hz.
I don't see a drawback in using a 0.1uF input capacitor. It's very unlikely that you will hear a difference - at least no negative difference.
What I want to say: in case there is some very low frequency included in the music, it is unlikely you will hear this frequency (because of output capacitor and speaker size), but the amplifier will amplify this signal. At high volume this may cause the amplifier to clip, causing distortion. This usually is not what you like.
Thus I rather see a benefit in using a 0.1uF capacitor against a 1uF capacitor.
Depending on what music you want to hear, what volume you want to use and what size and quality of your speakers...I recommend to use an even lower value capacitor...to reduce early clipping.
It doesn't make much sense to amplify a signal that you can't hear.
In either case use a foil capacitor, no electrolytic, no ceramics.
Klaus
A good headphone should be able to reproduce 27Hz.I found an online tone generator last night that helped a lot too.
