VHDL "library" and "use.all" clause
shaiko
Advanced Member level 5
Hello,
Consider the following code before the entity section of a .vhd file:
library x;
use x.all ;
As far as I understand the first line tells the compiler that 'x' is a library and the second line makes all the packages in this library visible for the entity to follow.
Am I correct?
Yes it does, plus all the entities, but it does not make their contents visible.
Reactions: shaiko
    shaiko
Re: VHDL "library" and "use.all" clause
Mind reading my next question...
If it doesn't make the contents visible, what's the motivation of simply making the package & entity names visible?
Because you don't need the library name when you use direct instantiation for an entity or create a new package from a generic package.
Eg
Inst : entity some_entity
Port map (
That's about the only use I know.
Reactions: shaiko
    shaiko
And how would the same instantiation look if I wouldn't use
library x;
use x.all ;
Then you would use:
Inst : entity [COLOR="#FF0000"]x.[/COLOR]some_entity
Port map (
Reactions: shaiko
    shaiko
Consider the following real life scenario:
altera_mf is a library name.
altera_mf_components is a package inside this library.
dcfifo_mixed_widths is a component inside this package.
I tried all of the lines below - and they all compile,
Can you please explain what does each of the lines mean and how they differ between themselves?
inst : entity altera_mf.altera_mf_components.dcfifo_mixed_widths
inst : entity altera_mf_components.dcfifo_mixed_widths
inst : entity altera_mf.dcfifo_mixed_widths
Not really any different.
1. Full path to component.
2. Component from visible package
3. Entity from library
For 1 and 2, your just instantiating the component and mapping it during elaboration
3 is a direct entity instantiation
Reactions: shaiko
    shaiko
Is there a way to make visible all packages of a library and all their components with a short code?
Something like:
Library some_library.all.all ;
see https://www.doulos.com/knowhow/vhdl_designers_guide/vhdl_2008/vhdl_200x_merged/#context
-- vhdl 2008
library ieee;
context ieee.ieee_std_context;
-- replaces
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
standard caveats about vhdl-2008 support apply. same for "work" being a special library.
-- this code would be in a file compiled into <some library>.  it doesn't need to be ieee or unisim.
-- it would be accessed with:
-- library <whatever>;
-- context <whatever>.xilinx_with_mostly_safe_math;
context xilinx_with_mostly_safe_math is
  library ieee;
  use ieee.numeric_signed."-"; -- gets both one and two arg forms
  use ieee.numeric_unsigned."+";
  use ieee.numeric_unsigned.to_integer;
  library unisim;
  use unisim.vcomponents.all;
end context;
Using
and
inst : component altera_mf_components.dcfifo_mixed_widths
Both compile...Is it the same??
Iirc, using component keyword is for a component instantiation, and is optional. Using entity will compile against an entity. If you're compiling in quartus it's a bit more relaxed about things.
Wondering why it's important. Is this just academic?
Just to know the rules...
I simply noticed that the same code that compiles with Modelsim, generates errors in VCS.
