Melkocha
Newbie level 5
In the construction of an RF amplifier circuit at 40MHz using this component, I find that this oscillation disappears only if I place a straight and vertical wire of 20 mm at the output and parallel to the receiving antenna.
I must clarify that this circuit captures the signal of an antenna located at about 15 mm.
Is there an alternative way to avoid the use of that trick to avoid spurious oscillations?
Thank you in advance!
