ODDR VS ODDR2 I use Virtex-4
abimann
Member level 4
Member level 4
Does someone use faced problem , I want to use Hamsterworks minimal HDMI, but my Virtex-4 use ODDR i made many manipulations but now result
instead :
HTML:
c0_to_serial: ODDR2
   generic map(DDR_ALIGNMENT => "C0", INIT => '0', SRTYPE => "ASYNC")
   port map (C0 => clk_x5,  C1 => not clk_x5, CE => '1', R => '0', S => '0',
             D0 => C0_output_bits(0), D1 => C0_output_bits(1), Q => c0_serial);
I use :
HTML:
c0_to_serial: ODDR
   generic map( DDR_CLK_EDGE => "SAME_EDGE",--"OPPOSITE_EDGE"or"SAME_EDGE"
	INIT => '1', SRTYPE => "ASYNC")
   port map (C => clk_x5, CE => '1', R => '0', S => '0',
             D1 => C0_output_bits(1), D2 => C0_output_bits(0), Q => c0_serial);
Could someone has same problem, I am sure problem is here .. pls help SOS!!!
you have the data input swapped. rising edge data has changed from D0 to D1. fall edge data has changed from D1 to D2.
Reactions: abimann
    V
    abimann
