[SOLVED] problem simulating a simple counter in VHDL with Vivado
joseMiguel
Member level 5
Member level 5
Montpellier FRANCE
hi guys,
here below the counter
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity count16 is
port(
    CLK, nRESET, LOAD : in std_logic;
    D : in std_logic_vector(3 downto 0);
    Q : out std_logic_vector(3 downto 0));
end count16;
architecture archcount16 of count16 is
signal TEMP: unsigned(3 downto 0);
begin
    core : process(nRESET, CLK) begin
        if (nRESET = '0') then
            TEMP <=(others => '0');
        elsif (rising_edge(CLK)) then
            if LOAD = '1' then TEMP <= unsigned (D);
                            else TEMP <= TEMP + 1;
            end if;
            --TEMP <= TEMP +1;
        end if;
    end process core;
Q <= std_logic_vector (TEMP);
end archcount16;
the testbench
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
-- Company:
-- Engineer:
-- Create Date: 15.05.2018 16:59:07
-- Design Name:
-- Module Name: count16_tb - Behavioral
-- Project Name:
-- Target Devices:
-- Tool Versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity count16_tb is
--  Port ( );
end count16_tb;
architecture Behavioral of count16_tb is
COMPONENT count16
PORT(
    CLK : IN std_logic;
    nRESET : IN std_logic;
    LOAD: IN std_logic;
    D : IN std_logic_vector(3 downto 0);
    Q : OUT std_logic_vector(3 downto 0));
END COMPONENT;
    signal CLK : std_logic := '0';
    signal nRESET:  std_logic := '1';
    signal LOAD:  std_logic := '0';
    signal D : std_logic_vector(3 downto 0) := "0000";
    signal Q : std_logic_vector(3 downto 0);
    constant CLK_PERIOD : time := 20 ns;
begin
dut: count16 PORT MAP(
    CLK => CLK,
    nRESET => nRESET,
    LOAD => LOAD,
    D => D,
    Q => Q
RESET_generation: process
    begin
    nRESET <='0';
    wait for 170 ns;
    nRESET <= '1';
    wait;
end process RESET_generation;
CLK_generation: process
begin
    CLK <='0';
    wait for CLK_PERIOD/2;
    CLK <= '1';
end process CLK_generation;
end Behavioral;
i succeed to launch the simulation but all is undefined.
there is no trace of the testbench
thank you so much for having read that post.
regards
joseMiguel
I'm guessing some file issues. I don't see anything that would allow "all" signals to be undefined. Or really even any of them to be undefined. My guess is that one or more files is not compiled, was changed and you are using an older version, or that you are not running the simulation.
I do agree that placing the async reset exactly on a clock edge isn't desirable.
I agree. Output must be defined zero at least during reset. And timing violations don't show in a functional simulation. So probably a trivial simulation configuration problem.
hi guys,
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
library ieee;
entity count16 is
port(
end count16;
begin
            end if;
            --TEMP <= TEMP +1;
        end if;
    end process core;
end archcount16;
the testbench
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
-- Company:
-- Engineer:
-- Design Name:
-- Project Name:
-- Target Devices:
-- Tool Versions:
-- Description:
-- Dependencies:
-- Revision:
library IEEE;
--library UNISIM;
--  Port ( );
end count16_tb;
COMPONENT count16
PORT(
    CLK : IN std_logic;
    LOAD: IN std_logic;
END COMPONENT;
begin
    CLK => CLK,
    nRESET => nRESET,
    LOAD => LOAD,
    D => D,
    Q => Q
    begin
    nRESET <='0';
    wait for 170 ns;
    nRESET <= '1';
    wait;
begin
    CLK <='0';
    CLK <= '1';
end Behavioral;
regards
joseMiguel
What do you mean by no trace of the testbench? Do you mean there are no waveforms displayed? If this similation was run with a script the you are probably missing -debug typical on the xelab command. If you don't use that switch the default is no visibility.
Thank you so much, as i am a big beginner with Vivado, i forget to specify that the testbebch is the top level design.
Now i have the right functionnal simulation.
regards
jose Miguel
(now i need to learn about constraints)
