How to polarise the Deep N-Well (WB) or tap WB in the layout
tisheebird
Member level 5
Member level 5
Hello
I have done the layout but need to tap WB or polarise "DNW" so please anyone could tell me how we can do it.?
I need to polarise it to VDD right..?
Please guide me with the steps.
You need to connect a VIA from nwell to the appropriate metal you tend to use. to check the correct via if you don't know I advice you to use LVS test.
You need to connect a VIA from nwell to the appropriate metal ...
No: From nwell (or any other silicon surface) you need a contact opening (not a via) to metal1 . In ICs, vias are ties between different metal layers only. Simply a naming convention.
You saved me. I just fixed it in my report thanks to you.
I think it is important to know the naming conventions
Your help is really appreciated
Need to check your layout design rules. Some processes with dnwell require some type of termination ring around the edge of the dnwell. It is all dependent on the technology
